GTX 660 Problem
Grimmeh
239
I uninstalled the On board graphics and my GTX 660 MSI OC does not respond to the monitors, yes the VGA was connected to the GPU when booted up but its still not responding to the Monitors, when I uninstalled the Integrated GPU(APU) it was on the same resolution. The Integrated GPU would only respond if the GTX 660 MSI OC is off the motherboard. My motherboard is a AAHD2-HY(Holly2).
Any Ideas?
I did receive word that the Mobo does support the GTX 660 and My computer is an APU. and the computer model is the p6-2376.
And My PSU is 500w EVGA 80 Plus
For the GTX 660?
No drivers were installed for it because the Nvidia Software could not detect the GTX 660, but when I try to use the GTX 660 it wouldn't respond to the Monitors including the on board one unless I take out the GTX 660
Well it needed to be detected, the GTX 660 was not in the Mobo, but when it does it would not respond to monitors
It was installed in the motherboard, the problem is the GPU would not respond to the Monitors, like it won't display, the computer does have Integrated Graphics, I tried to Uninstall/disable it and could not work, the only VGA that responds to the Monitors is the On board graphics.
No and the GTX 660 does not respond with the monitors is because of the APU Graphics keeps re-install/enable and I do not know how to prevent that and I would go through BIOS(Windows 8) and there is no option to disable it. I did device manager and it would do great but it will keep re-install/enable automatically which prevents the GTX 660 from displaying.
Well I would install it, connect it, boot it up and it would not respond to the monitors, while the GTX 660 was still installed to the motherboard, I tried the Integrated Graphics VGA and that would not respond either
When I saw the check about Integrated Graphics, thats what I did and nothing happened, just no display between the Integrated Graphics and the GTX 660 when its installed to the Motherboard
