GTX 670 FTW or GTX 770 or 7970 PLEASE HELP
ryfty
41
which one should i get. i plan on using it for around a year to play games like gta v, rome total war 2, and watchdogs @ 1920x1080
evga gtx 670 ftw : £275
PALIT GTX 770: £310
GIGABYTE 7970 OC : £300
ALL FROM AMAZON
which one would be the best choice. also i would not mind overclocking aswell so whichever has a better overclocking headroom would be a factor.
also which one is the best quality and runs the most quiet. all help is appreciated.
A 770 would be your best bet in my opinion, plenty of performance, low power consumption, and new technologies such as GPU Boost 2.0. If you can, consider a Windforce 770 from Gigabyte or a DCUII model from Asus, those are both really, really nice cards. If not, the Palit is probably fine.
Btw the 670 ftw edition is currently £269 on novatech.
I'm in a similar dilemma, but I want it for a lot longer than a year so I'm swayed by the extra gb of vram on the 7970 ghz edition because it's difficult to see if 2gb vram would be enough for next gen.
But in your situation, if you only want it for a year then get the 670 ftw.
+1 to that. I just picked one up (from Novatech) and it does play Crysis 3!
