GTX 760 not POSTING HELP
lhikary
322
just installed brand new gtx 760 from zotac
system made 4 beeps and didnt post
disabled internal graphics with no hhelp
should i update the bios ? its from 2012
i have a 550w from thermaltake and its 80 plus bronze
its a a 4x slot in my mobo which is a gigabyte z77-d3h
i have a 16x
and a 4x
does 4 works?
Yes, the x4 should work.
ok i will try and if it didnt work i will update the bios
same problem
didnt update the bios cuz it couldnt detect the usb drive
i have this psu
http://www.thermaltake.com/products-model.aspx?id=C_00001818
no use in deleting intel hd drivers cuz i cant get in windows witth the gpu power plugged in tt
Return the GPU as it seems it's faulty. If that doesn't help, you might have to change the motherboard.
