[SOLVED] Gtx 760 with low usage
Jan 13, 2019
7
Hi i recently bought a gtx 760 to replace my gt 710 but the problem is that the gpu usage is below 30 i uninstalled the gpu driver using udd and i downloaded the latest gpu driver from nvidia and the problem is the same i even disabled all power saving fonctions and same thing i suspect it's an bottleneck cause my cpu is a dual core e5800 and it could be also the psu cause im using an adapter 6pin to 8pin and im having an msi twin forzr oc by the way it requires an 8pin and 6pin and the psu is 800w
That e5800 would definitely be a bottlneck. I ran one of those for many years and it's a long way from component in gaming for a while now.
