GTX 780/i5-4670K build, Kindly help me decide on rest of the parts.
Salma_75
30
Hello,
Building a gaming PC for MMO's , Entertainments & 3D .
I don't plan to overclock , add another GPU card , or modify the system in any way.
I'll buy all parts from this site : http://gear-up.me/, So far i decided on:
GPU: http://gear-up.me/gigabyte-gtx780-3-gb-384-of-active-2xd-h-dp-d5-oc.html
Price is 2191 AED/597$
CPU: http://gear-up.me/cpu-intel-core-i5-4670k-box-3-4-ghz-lga1150-vga.html
Price is 973AED/ 265$
So, This is what i need to know:
1- Is this GPU an overkill for MMO's and 3d?"I only change PC's once every 4 years".
2-Can you help me pick a PSU, Case, MOBO ,HDD & 8GB RAM from same site "gear-up.me/"? my budget for them is 1800AED/500$
I'll pick best answer and rate , thank you in advance :)
I think for 4 years this card is a good choice as it will be able to play the newest games in 4 years time (on lowered settings of course). Here are the rest of the parts i recommend:
ITEM NAME
PRICE
QTY SUBTOTAL REMOVE
BACK TO SHOP UPDATE SHOPPING CART
8 GB of DDR3-1600MHz Kingston HyperX Blu 2x4GB XMP kit
203652432424
Weight: 0.09 kg
342.00 AED 342.00 AED
Remove item
1TB HDD WD10EZRX 64 MB SATAIII/600 IntelliPower2RZ
20420090726
Weight: 0.45 kg
261.00 AED 522.00 AED
Remove item
Fortron FSP500-60GHN 80PLUS BRONZE, black, 500W
209132252
Weight: 1.62 kg
250.00 AED 250.00 AED...
ITEM NAME
PRICE
QTY SUBTOTAL REMOVE
203652432424
Weight: 0.09 kg
Remove item
20420090726
Weight: 0.45 kg
Remove item
209132252
Weight: 1.62 kg
Remove item
ASUS B85M-G
ASUS B85M-G
2008227
Weight: 0.66 kg
312.00 AED 312.00 AED
Remove item
Fractal Design Core 1000 USB 3
209053123
Weight: 7.73 kg
338.00 AED 338.00 AED
ORDER TOTAL
Grand Total 1,764.00 AED
Also, as mentioned above, you do not need a K series CPU (in fact the motherboard suggested in my post cannot overlock)
I suggest you go with an i5 4570. This way you will be saving 100AED while having nearly the same performance.
http://gear-up.me/cpu-intel-core-i5-4570-box-3-2-ghz-lga1150-vga.html
@Plushthinking Iq:
1) The power supply series GM from cooler master SUCK! The forton i suggest is both cheaper and made by a REPUTABLE PSU maker, FSP (also make corsair HX and TX power supplies as well as other high tier branded PSUs).
2) That case is too expensive and would go above his budget.
