Gtx 950 xtrme gaming max fps drop in dota
Vishalka97
Commendable
Aug 31, 2016
4
System specs
Asus b150 gaming aura
Core i3-6100 3.7ghz
Ram : team delta 4gbx2
Hard disk: toshiba DT01ACA100 (AAA)
Windows 10. 64bit
I recently built this pc.. Fps were betweeen 80-120 dota maxxed out at 1366x768 resolution
After few days now even with the lowest graphics ping is at 60... But it drops randomly about every minute below 20
Plz guys help me! It will be a great hand for me
Thank you
install msi afterburner
turn on cpu/gpu temp monitoring in the OSD
turn on cpu/gpu usage monitoring as well
play the game, post back max temps for both cpu and gpu, also max usage on the cpu/gpu
Max cpu temp: 51
Max gpu temp: 42
Max gpu usage 60% (went for 96 for 1 second and back to 60's avg)
Max cpu usage 70-80 (went to hundread when i was swithing programmes)
chrome,dota msi after burner was running when i was taking these readings
temps are good
run a scan with a anti-spyware program
also run a memory scan on your ram with memtest86
do you have windows set to high performance under the power options?
also choose max performance under the nvidia panel
stuck at 60 fps max? make sure you turn off vsync, that locks your max fps
its been a week now fixing my rig..i used to run dota 2 without changing any motherboard stuff..it was on optimized in ai suite 3 (asus) i could just run dota2 at 1366x768 around 80-120 fps
recently im being experiencing this situation
my power supply provide a 6+2 connector i guess it should be okay
i tried re-installing drivers ..yet same issue
i didnt format and re-install windows though just using the same hard disk where it was being used in an old intel dh61ww motherboard
i just now tried re installing drivers i guess the fps is back to normal thanks for da help MAXALGE
Thank you very much :)
