Question GTX 960 Twin Frozr 2GB vertical mount
Ayatollah
78
my gpu runs on 1x8pin power connector, but i have a 1x6pin which i use and it works fine.
The case i've ordered has vertical mounts for the gpu as well as the normal horizontal mounts, but i think that vertical mounting just looks way cooler but i don't have a pcie vertical mount cable. Yeah i know i can get one from ebay or amazon, but is it possible to power my gpu entirely from the 1x6pin power connector?
If the card fires up with just the 6 pin alone have you kicked it up with a game.
The card having the 8 pin connector has those two extra pins that are grounds. It's a way the industry tried to take the oops out of the installers hands.
There is a sensor ground to tell the GPU you have a power supply that matches the power required to run a 8 pin GPU. With that said a quality Power supply that has only has 6 pins works fine on lower demanding cards.
But I would still get a 6 to 8 pin adapter from amazon.
But all this is moot if you have a low quality power supply.
Please list your make and model of power supply so we can reply with a yes or no if WE would use what you have for what your asking.
sorry i think i made my question kinda weird lol sorry
I meant can i power my gpu off the 1x6pin only, not the pciex16 slot?
