Gtx 970, idle temp gone up after going 4k normal ?
CalypsoIce
14
I noticed that the temp of my gtx 970 palit jetstream has gone up to 50-60 while idle from 40-45 on my old 1080p monitor. Is this normal ?
gpu temps under 70°c are very safe can change your fan curve to keep it cooler at idle. I think my gpu fans turn on at 65° and cool it back down to 50°
While playing battlefield 4 the temp goes up to 70, Fan duty also goes to 70%.
I have the gtx 970 palit jetstream, the fan will remain off untill the temp goes to 60.
Should i change it so the fan is constantly on to get lower idle temps or is this normal ?
So it would be smart to keep the fan on even when idle and not keep it off untill the temp reaches 60 ?
