madmatt30 :
To nip a few things in the bud, joshyboy & phononboy have covered most if it.
1. A stock 6300 WILL limit the upper fps on newer titles paired with a 970.
2. Overclocked to 4.2ghz you will net above 50fps solid in every title apart from a select few.
3. That GTA v bench is hopelessly outdated , updates allowed a lot better multi core use , you will rarely see a 6309 drop below 50fps at any time now.
4. Your 1366x768 monitor is a bigger 'bottleneck' - I use that term loosely , at 60fps you won't see above 60% usage- the benefits - it'll run incredibly cool & quiet & offers you headroom for the future, a 960 or 380 would have given you pretty much the same performance at that resolution though.
Put it in your system, enjoy it & stop worrying though , & yes the division at ultra is easily possible at that resolution.
The FX-6300 has a max turbo value of 4.1GHz.
I'm not familiar with the exact overclocking options, though most CPU's have power saving techniques so may change the CPU multiplier as the load increases. Hence the "max" value may be 4.1GHz, and while gaming it may be closer to 3.9GHz.
If we assume the overclock is 4.2GHz under normal gaming load (one multiplier or start higher than 4.1GHz and drop like normal) then this is 42/39 or under 8% theoretical max processing improvement.
With a heavily CPU bottlenecked game that might only mean about a 5% FPS improvement such as 58FPS going to 61FPS.
I mainly wanted to point out that the real-world benefits aren't necessarily that large ( a couple game tweaks that don't change graphics much can often do as good or better).
Other:
*If planning to upgrade the PC as I said before, think carefully about the MONITOR. So many people have crappy monitors and expensive gaming rigs. Since GSYNC is pretty expensive, the monitor to choose depends on:
a) overall budget for monitor + PC
b) when you could replace the monitor (two years?) for a good GSYNC model (NVidia GPU)
Monitor examples (some warranties are way better than others. Some Dell have great, and some Acer crappy like Dell 3-year, zero dead pixel, pre-paid waybill to return vs 1-year, some dead pixel etc but it VARIES a lot. Keep in mind when seeing cheaper Acer pricing for what seems similar):
$140 (IPS, 5ms, 1920x1080, 23", 60Hz)->
http://pcpartpicker.com/part/asus-monitor-vs239hp
$260 (IPS, 4ms, 2560x1440, 25", 60Hz)->
http://pcpartpicker.com/part/acer-monitor-umkg7aa002
(I bought my sister the Dell version for a bit more money)
$260 (TN, 1ms, 1920x1080, 24", 144Hz)->
http://pcpartpicker.com/part/asus-monitor-vg248qe
$800 (GSYNC, IPS, 4ms, 2560x1440, 27", 144Hz)->
http://pcpartpicker.com/part/asus-monitor-pg279q
$1100 (GSYNC, IPS, 4ms, 3440x1440, 35", 100Hz)->
http://pcpartpicker.com/part/acer-monitor-z35bmiphz
So...
A lot of pros and cons. I have a GTX680 which is approximate 70% fast as a GTX970 (for titles with minimal CPU bottleneck).
However, I have a 2560x1440, IPS panel. I love it not just for desktop usage, but for games with a lot of small text/HUD elements such as CIV5. For games like Skyrim the resolution isn't nearly as important and may not look much better beyond 1920x1080. Having said that, I also prefer 27" or higher monitors which aren't ideal for monitors with only 1920x1080 physical pixels at close distances such as two feet away as you can see the individual pixels. So we can't just compare the resolution here.
144Hz panels add a lot to the cost to the point you may have to choose between that or a higher resolution at 60Hz. If you play fast games like shooters then 144Hz might make a lot more sense.
4K models are extremely problematic. Currently the refresh rate is limited so not ideal for gaming. Processing power goes up a lot for usually a minimal visual difference. Many desktop applications have scaling issues that worsen as resolution increases. I do like 32", 4K, IPS panels for productivity though such as multiple programs on-screen rather than multiple monitors. Even then, if you don't mind ultrawide the 3440x1440 is a nice option (price aside).
Asynchronous monitors as said are awesome but add a lot to the cost. I'd like to see that $800 panel drop to $500 or less in another year. I think it may do so.
The best gaming monitor is arguably the $1100 model I listed. Even then there are pros/cons as the refresh rate is a maximum 100Hz, and ultrawide might not be desirable for some games (though you can just have black bars of course on left/right).
My point again with listing these is to suggest you PLAN your upgrade path over a few years. So maybe something like the $140, 1080p, IPS now and keep that for a few years that go with a GSYNC (or AMD + Freesync) arrangement.
Actually, the cost of a 1080p monitor plus replacing your current rig probably gets close to $800USD. If I was going to upgrade your rig I'd be going with:
- monitor, plus
- i5-6600K + mobo + 16GB DDR4 + Windows 10 64-bit + CPU cooler?
That is adding up close to $800. It's pretty hard to compare both scenarios though:
a) GSYNC 1440p only change
- lower FPS overall for CPU bottlenecked games
- games SMOOTHER (can have similar or better at lower frame rates too)
- higher res, larger screen, and better picture (vs basic 1080p monitor)
b) 1080p 60Hz + Skylake replacement
- FPS higher in most games (doesn't necessarily mean smoother or better experience in a particular game though)
Summary:
Most people would replace the core PC. I would personally replace the monitor if the above was my only option due to budget.
Based on everything so far though I'd suggest doing NOTHING (aside from optimizing tweaking for games) and wait until 2017 at least to see how AM4 affects pricing. I'd take Intel unless the benefit is significant. $50 for a CPU may seem like a lot in savings but it's 5% on a $1000 build so keep that perspective.
Skylake quad-core CPU's have about HALF the space used by the GPU portion. Thus, AMD may be able to create an 8-core for about the same size (without GPU.. which would be an APU anyway) and same or possibly cheaper price. We'll see.
I think Zen CPU's and Zen/Polaris APU's are going to do very well. Probably also the next APU or nearly identical for the PS5/XB consoles near 2020 as well.
Okay, must stop talking...
