My specs are,
i7 6700k 4.0 Ghz
GTX 980 Ti Golden Edition
2x8 16 GB 3000Mhz (Running on 2133, X.M.P off now)
MSI z170a Gaming m7
Zalman ZM700-GT 700W
Zalman H1
Win 10 Pro 64 bit
Asus VG248E 144hz 1ms 1080p
I have getting 150-250 FPS on CS:GO (1280x1024 4:3) Low Settings, I want +300 fps for this system. Most people have getting more FPS with less than 980 Ti. This is annoying situation for me.
Also the other games GTA 5 1080p 144hz - all highest (very high-ultra) 16xAF 4xMSAA +FXAA -45-63 FPS
Witcher 3 -all ultra- 41-48 FPS.
Is there a problem with these values?
My friend has almost the same system, i7 6700k 16 GB 2133 corsair Ram and GTX 1060 6GB.
He has getting +300 fps cs:go.
Nvidia driver : 378.49
Cs:Go launch options "-novid -nod3d9ex -threads 8 -high"
Power options - High Performance
My Nvidia Panel 3D settings
Ambient Occlusion: off
Anistropic Filtering: off
Antialiasing - FXAA: off
Antialiasing - Gamma correction: off
Antialiasing - Mode: off
Antialiasing - Setting: off
Antialiasing - Transparency: off
CUDA - GPUS: all
Maximum pre-rendered frames: 1
Multi-display/mixed- GPU acceleration: Single display performance mode
Power management mode: prefer maximum performance
Shader Cache: on
Texture Filtering - Anistropic sample optimisation: on
Texture filtering - Negative LOD bias: allow
Texture filtering - Quality: high performance
Texture filtering - Trilinear Optimisation: on
Threaded optimisation: on
Triple Buffering: off
Vertical Sync: off
Virtual Reality pre-rendered frames: 1
i7 6700k 4.0 Ghz
MSI z170a Gaming m7
Zalman H1
Win 10 Pro 64 bit
CUDA - GPUS: all
Shader Cache: on
Vertical Sync: off
