Specs: eVGA GTX 980 ti SLI, 2x Samsung 28e590D monitors, eVGA SuperNOVA 1200 P2 Power Supply, AMD FX 9370 water cooled, GTX 980 ti's running SLI.
One monitor I could run a Twitch stream and play games like GTA V maxed etc no issues with the Twitch stream minimized in the background.
However I purchased my second 4k monitor this week and hooked it up tonight and tried running GTA V on one of my monitors and shifted the Twitch stream over to the second monitor. (I'm mirroring the desktop so not extending into some crazy resolution.) both monitors are running 3840x2160, anyway everything is working fine for the first 5 minutes of game play, after that the 2nd monitor starts flickering black and moments later my PC freezes and goes to a blue screen.
My suspicion (IS that 980 ti's can't handle dual 4k.) I just want to confirm them, or is one of them faulty etc, could it be that I have one hooked up via DP, and one HDMI?
Is there a way to get this configuration to work? Is this actually a CPU issue? These are things I want to rule out before deciding on purchasing Titans. Can the Titans even run 2 4k monitors?
Thanks!
Specs if needed.
CPU: AMD FX-9370 Black edition 4.4 GHz
CPU Cooler: Corsair H110i GTX Liquid CPU Cooler
Motherboard: ASUS ROG Crosshair V Formula-Z
Memory: 1 x G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3
Storage: SAMSUNG MZ 500GB Solid State Drive
Video Card: Dual Nvidia GeForce GTX 980 Ti Video Card
Case: Corsair 760T White ATX Full Tower Case
Power Supply: eVGA SuperNOVA 1200 P2
Operating System: Microsoft Windows 10 (64-bit)
Keyboard: Razer Ananasi
Mouse: Razer Deathadder CHROMA
Monitor: 2x Samsung 28" 4k monitors @ 60hz
-edited to update correct power supply-
Thanks!
Specs if needed.
