[SOLVED] GTX Titan X Hybrid - Broken Liquid Cooler. Please Help.
Dec 18, 2020
Hi. I bought a Titan X Hybrid back when they were new in 2015. The liquid cooler broke and leaked. The GPU still functions, but runs super hot.
Could someone please point me in the direction of a replacement cooler that is compatible? An air cooler would be totally fine. I've tried looking but can only find discontinued, out of stock coolers or solutions for the Titan X Pascal (hybrid is Titan X Maxwell).
Thank you in advance.
Seems like there isn't any you could try looking on ebay but I doubt they have. There could be some from china but I wouldn't trust their shipping tbh.
your best option is to buy an after market cooler like artic.
You could also get an NZXT G12 bracket but you're gonna have to buy an AIO kit thats compatible with it.
https://www.nzxt.com/products/kraken-g12-white
I've checked the specs and it seems to support Titan X cards.
Or like I said earlier a air cooler instead like this...
https://www.amazon.com/ARCTIC-Accel...la-552870563939&ref=&adgrpid=67183599252&th=1
It says in the description that it also supports Titian x
Reactions: Separate
Thanks man.
I think I'll go with the Arctic. It says Titan X Pascal, Titan Xp (p for pascal again), and Titan X. I'm a little bit skeptical that it might not be compatible with Maxwell (the hybrid version card), but it might be my only option.
I won't be buying it until January, so if anyone else has any input or suggestions I would still really appreciate it.
