[SOLVED] GTX1060 not enabled for 2nd monitor
Aug 30, 2019
4
I have a 15.6" ASUS ROG ZEPHYRUS M GM501GM-EI005T laptop and when I run a 2nd monitor from the hdmi output it does not use the gtx 1060 for the 2nd display. It uses the integrated only 🙁 Is there any way I can play games with the GTX1060 on my external monitor?
What happens if you leave the external monitor connected and close the laptop. You might have to change what happens when you close the lid for power options.
