Gunship 2000 Install problems
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.flight-sim,rec.aviation.simulators (More info?)
Hi all
Installed the program in the past and want to play around again but am
having problems installing it. I get 2 error messages
C😛ROGRA~1\Symantec\S32EVNT1.DLL. An installable virtual device driver
failed Dll initialisation. Choose 'close' to terminate the application.
C:WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running
MS-DOS and Microsoft Windows applications. Choose 'Close' to terminate the
application.
Both of these popups have a close ignore option...selecting either has no
affect...it doesn't install. I have used the program on this computer in the
past, which by the way is XP pro athlon 1.8, 64Meg Gforce2 512Meg SDRAM at
333 clockspeed. Not great I know but it's all I got.
Any ideas?
Scet
In article <41f4da5e_1@news.iprimus.com.au>,
I used to play it quite a lot too. The team-element was very
fascinating for me, but the game itself was a bit arcadey. Your gunship
could endure several direct missile hits and so on. However it was the
best helicopter simulator/game at the time, and pretty much the only one
i've played to an extend worth mentioning. I had better get myself
Longbow 2 (which reminds me: i do have the first Longbow /somewhere/) or
that Kamov vs. Hokum or what was it.
I can't help you much regarding the first error message, about
S32ECVT1.DLL failing to initialize.
> application.
This is propably because that file doesn't exist by default. At least
it didn't on the Windows XP Pro installation i've used. Creating that
file remedied Alley Cat not starting. Hmm, if the fine folks at
Microsoft decided to supply a DOS-emulation subsystem, why didn't they
bother to create such a default configuration that it would at least
initialize. Oh well, maybe they had other things to mind too.
Anyway, just create that file, it ought to do it.
> [this machine is] XP pro athlon 1.8, 64Meg Gforce2 512Meg SDRAM at
No need to get shy, i don't think people are measured by figures of
their rigs. If i remember correctly, i played it on an MS-DOS 5.0
running on 8MHz 286, with 6MB RAM. Creative SoundBlaster 1.5 for the
rumble.
> Scet
..mace --- öäfdf +f lre
