Guys Help! What Graphics card should I get?
zlatan82012
Guys im building my first PC.
Heres what I've got so far:
CPU - intel core i5 3570k
Mobo - Gigabyte GA-Z77-DS3H ATX LGA1155
RAM - 2 x 4gb Corsair Vengeance black
HDD - Seagate Barrcuda 500gb SATA 7200rpm 3.5''
Case - Corsair SPEC-01 RED ATX Mid Tower Case
PSU - Corsair Builder 750W 80+ Bronze Certified ATX Power Supply
(let me know what you think about all my part choices)
But I am really struggling to chose a graphics card... my budget is around £200 ($340)
Can anyone advise me on which card gives me the best performance on this budget?
Look at the regular r9 290, quite a bit cheaper than the 290x and almost as quick. Make sure you get one with a good cooler though, the reference coolers are loud and dont cool very well.
