I’m having problems with my cpu it says I have 4 cores, 8 logical processors, and 8 enabled cores, but I’m worried about my temperature and that my cpu only has 4 cores. Please help me
After all 8 cores and 16 threads are enabled, you will have a lot more heat to worry about. What heatsink do you have?I’m worried about my temperature
what are the specs? please always list the complete specs if you're asking something.I’m having problems with my cpu it says I have 4 cores, 8 logical processors, and 8 enabled cores, but I’m worried about my temperature and that my cpu only has 4 cores. Please help me
I have a stock cpu coolerRun msconfig. On the Boot tab press the Advanced options... button. Make sure the Number of processors box is not checked. Press OK. After you exit out of msconfig you will need to reboot so Windows can find all available cores and threads.
Intel stock cooler is the worst cooler when it comes for that cpu, also did you upgrade your system or it's brand new?I have a stock cpu cooler
My pc is a few months old I got it in mayIntel stock cooler is the worst cooler when it comes for that cpu, also did you upgrade your system or it's brand new?
No, i mean did you upgrade your old pc while using the same boot drive? or it's totally a recent build pc?My pc is a few months old I got it in may
recent buildNo, i mean did you upgrade your old pc while using the same boot drive? or it's totally a recent build pc?
If you don't mind, update the bios to the latest then load optimized/default settings, and see if windows detect it as 8 cores 16 threads. also please use a better cooler, that cpu is a beeferrecent build
my pc is already running on 8 cores 16 threads and if you don't mind me asking what would the bios do or would it reset anythingIf you don't mind, update the bios to the latest then load optimized/default settings, and see if windows detect it as 8 cores 16 threads. also please use a better cooler, that cpu is a beefer
do you know of any good cpu coolers that arent that expensive?Intel stock cooler is the worst cooler when it comes for that cpu, also did you upgrade your system or it's brand new?
Did you use msconfig to fix the problem you were having? Did you mark that answer as solving your problem? That will help the next person that has this same problem.my pc is already running on 8 cores 16 threads
Depends on your budget. Deepcool Gammaxx 400s is good and pretty cheap, i use them with Gelid GC Extreme and it performed really well (compared to stock paste). Other one is Hyper 212 Evo, ID Cooling SE 224 XT (if available in your country).do you know of any good cpu coolers that arent that expensive?
no it wouldnt! it's just the bios that make all the system work, hence why i recommend to update it 😀my pc is already running on 8 cores 16 threads and if you don't mind me asking what would the bios do or would it reset anything
sorry for the late reply but I ended up getting the arctic 34 esports duo and my mother board is a b560no it wouldnt! it's just the bios that make all the system work, hence why i recommend to update it 😀
Also what is your motherboard?
I got the arctic 34 esports duo!Did you use msconfig to fix the problem you were having? Did you mark that answer as solving your problem? That will help the next person that has this same problem.
The Intel cooler is junk but if you are only going to run your 10700F at default settings, the Intel cooler might be good enough. It is completely inadequate if you want maximum performance.
Your CPU has a default 65W TDP rating.
https://ark.intel.com/content/www/u...0700f-processor-16m-cache-up-to-4-80-ghz.html
When fully loaded, the 10700F will be forced to slow down significantly so it does not exceed 65W. If you want maximum performance, you need a much better cooler and you will need to increase the turbo power limits. If you cannot find the power limit settings in the BIOS, you can use ThrottleStop to increase your turbo power limits. I recommend getting a better cooler first.
https://www.techpowerup.com/download/techpowerup-throttlestop/
I just installed one of these on a friend's computer. It is nice and quiet when lightly loaded. Cooling is adequate for a 6 core 10600K running a 4.8 GHz all core overclock.I got the arctic 34 esports duo!
