h100i and h110 in zalman z11 case
Its only possible it you pop the top fins off and have the fans mounted up top ouside of the case, with the radiator on the inside.
You can also grab a dremmel and cut the bays out of the front and mount the radiator vertically.
or you can cut another hole in the bottom of the case next to the pre-existing one and mount in on the bottom of the case (you would have to remove the harddrive bays)
Otherwise I'd just do what I did and grab an H80 or a new case :3
Yes, its dual tower so its good some beefy cooling.
