H100i Corsair Link not reading CPU Temps
MrAmos123
36
Hi all,
I've got a Corsair H100i and a i7 5930K using Corsair Link.
But, when configuring my own 'Curve' in the configuration panel I've made it so it ramps up the RPM the hotter the CPU gets. (That's the idea anyway.)
http://i.imgur.com/fP8dVHJ.png - Here's the picture of the Curve.
Anywho, when I start a stress test, it doesn't do anything, like I cannot hear the fans speed up.
If I change it from 'Curved' to 'Performance Mode' it quickly starts to speed up.
The red line in the middle of the graph indicating the current temperature doesn't move at all during the stress test.
I was wondering why the Corsair Link doesn't listen properly to the CPU's temperature output.
Thanks,
Amos.
I can tell when they ramp up, there okay fans, but not great, just standard Corsair ones. But as you can see in this image, I initiate the stress test, and none of the Fan RPM's go up, at all.
http://i.imgur.com/0rqm2ae.jpg
If I try and move the H100i 'Cooler Fan/Pump' into i7 5930K it says "The device can be associated with its own sensor only."
And if I try and go to the group directly, I can only see this; http://i.imgur.com/7WKeVUU.png
