H100i GTX fan replacement?
Dirty_Sprite
Commendable
Mar 31, 2016
160
I plan on replacing the H100i GTX fans with corsair SP 120 Red LEDs because they're noisy af but I cant remember where to plug in the 3 pin (i think) on each of the fans onto the motherboard. Mobo is a Gigabyte GA-Z97X Gaming 3. The H100i GTX has just one connector for both of the fans it looks like, but if I buy the fans individually then I'll have 2 connectors for each of the fans.
So it won't make it any less noisy at all?
OK, so i plugged in the corsair link cable to the waterblock and to the usb header on the motherboard, but after I changed the setting to "quiet" the fan rpm now says 0, even though the fans are spinning very lightly. I tried setting it to performance mode but the speed doesn't change. I also tried to use SpeedFan and that didn't work either.
I checked the temps. My CPU is overclocked to 4.0GHz and at max graphics settings in GTA V I get around 55 degrees. No stutters or anything. Smooth 85-90fps @ 144Hz. Perfect. Thanks for the help, turns out all i needed to do was set it to quiet in corsair link 😛
