H100i replacement led fans?
Sojiro1
94
Hello got the corsair h100i
The only thing I don't like is the fans not having led.
I was looking
cooler Master jetflo
http://www.coolermaster.com/cooling/case-fan/jetflo-120/
Corsair 120m 2 pack
http://www.corsair.com/en-us/air-series-sp120-led-white-high-static-pressure-120mm-fan-twin-pack
I have very high temperature amd situation.... and it seems those cooler Master fans will push air much better, and have higher ranges. Corsair led fans stop at 1600ish rpm and that's cool for a case fan I guess...
I also seem to only have enough space for push or pull
The difference you're seeing is due to the CM fans being airflow fans and the Corsair fans being static pressure fans.
Because your fans are pushing/pulling air through something and not just moving air from one open space to another, you definitely want static pressure (SP) fans. They're specifically designed for this situation and the fans that came with your H100i are SP fans.
I'd personally go with the Corsair pack.
