Hi! as the title suggest, I have a h100i v2 AIO for my i7 3930k which I have a slight overclock (0.2Ghz over boostspeed). My pump is working as it should, I have custom fan curve to run at 60% when liquid temp is at 40cº. But for some reason my fans ramp up to 2840rpm when I am doing literally nothing, having cpu at 3% usage and temp being around 36cº. My CPU usually idle around 40-45cº which is also quite high for idle temps of a 3930k but I am not worried about that. I am worried about why my fans are going so high for no reason when the custom fan curve is put to 60% at 40cº. 60% is also the highest it is suppossed to go.
I can not for the life of me figure this out, Corsair Link is kinda wonky, I can put the fans to silence mode and they still spin at 2840 rpm. I looked it up and the fans are only suppossed to go to 2435 rpm? correct me if I am wrong.
My full PC specs can be found below.
