Hi all,
I am having some issues out of the blue with my system trying to play games. For a few months it ran no problem crushing games like Battlefield V and Fortnite at max settings 1440p and then randomly I started getting very low frames. For example, in Fortnite I would never drop below 100 frames even in the most intense areas of the map; however, now I sometimes drop into the 30s and I think it is because my CPU cooler might have some messed up settings, or it is dying somehow. My pump seems to be running at 0-500 RPM on extreme mode (maybe that's a sign it's dying or I need to fix something in settings?). I will attach a picture of the temps I'm getting from my BIOS and I will provide any additional info I can if anyone have the time to respond! Thank you!
edit: I have reinstalled thermal paste and reseated CPU 2 times to no avail. I am 99% sure the cooler is installed properly inside the case.
System specs: (all bios settings are default including CPU clock and voltage)
GPU: EVGA GTX 1080Ti SC Black
CPU: i7-8700k
RAM: 16GB (2x8GB) Corsair vengeance 3000MHz DDR4 RAM
MOBO: GIGABYTE Z370 AORUS Ultra Gaming
PSU: Thermaltake 650 watt Gold certified
HDD/SSD: 2tb HDD, 500GB M.2 sata SSD
CPU: i7-8700k
