hello friends. so i have just been worried about my gaming pc, because i think its getting abit warm.
PC Specs:
CPU: i7 6800K
GPU: GTX 1080
RAM: 64GB
AIO: h115i
Case: Corsair Carbide Series Air 540 Cube
so my AIO liquid temps are starting to get abit hot recently. and quite loud, so im just wondering what temps are really dangerous for my h115i and at what temps should it sit when im gaming.
when on idle the liquid temp (AIO) is about 34c-38c and when im gaming it goes up to 44c-46c and i dont understand why its getting so toasty. and i dont know if my cpu is also getting hot. my cpu package idles around 32c-35c
and when browsing google chrome with youtube playing on the background it goes up to 37c-43c. what should i do or what should i be worried about? every time i turn on my pc the cpu gets to +1c more than it was before
for example. if the CPU package was on 38c when i will turn my pc on. and after afew hours turn it back on from shutdown, then it will be 40c and not 38c.... a fast reply would be helpfull because im scared to overheat my pc
and thats why i need anwsers. again im more worried about my AIO liquid temps.
im using corsair link for my h115i fan controls,
this is my fan curve for my h115i:
25C : 25%
30C : 30%
40C : 40%
45C : 45%
55C : 60%
60C : 100%
And my pump is runing 3100 RMP. and under load pump is going up to 3300 RPM
screenshot:
note that this screenshot was taken while mid gaming, so all temps you see are underload. for expamle on the screenshot i was playinf cs:go
p.s i have been using this pc since 2017 so keep that in mind
PC Specs:
CPU: i7 6800K
GPU: GTX 1080
RAM: 64GB
AIO: h115i
25C : 25%
30C : 30%
40C : 40%
45C : 45%
55C : 60%
60C : 100%
screenshot:
