[SOLVED] H115i Platinum Radiator Fan Spinning after shutdown
Jan 22, 2019
Hi Guys, would just want to check if this behavior is normal. I have connected the sata power connector to the radiator pump. When I switch off my pc, the radiator fan lights go from RGB > Red color but continue spinning. Is this normal? Do i have to switch of the PSU power each time I power off my PC?
Hi guys, seems like I have found a solution. The issue seems to be with the my gigabyte z390 Aorus master bios settings. Enabling the "ErP" mode in bios makes it work correctly. Now the cpu fans no longer have the light nor does it spin after shutdown.
I agree. If the fans are still spinning after shut down, then they are not operating properly. I suggest double-checking your connections and BIOS settings. Is this behavior isolated to the CPU cooler fans (e.g. case fans)? There may be a fault with the motherboard if connected fans continue to spin after shutdown.
