[SOLVED] H310 chipset bus speed
No. A SATA drive will still perform that same. An M.2 SSD might not have the same performance or an M.2 slot may not even be available since there are only 6 PCIe lanes. The graphics card is connected to the CPU not the chipset, same with RAM.
If you look at the generic block diagram for the 300 series chips -- https://www.intel.com/content/www/u...sors-and-chipsets/coffee-lake-s/overview.html what is being talked about is the bus from the CPU to the "chipset". Having this slower means there are fewer things that can be connected. So the H310 has fewer USB ports. Fewer SATA ports etc. Scroll down on the link above and you will see a comparison table.
Thanks for reply
I don't need more usb and sata ports.
I only want to understand that with this motherboard my cpu, hard drive or ram speed (Performance) will be less or not. I mean can i have to compromise with any component's speed.
