[SOLVED] H370 Mining Master Boots Fine with 14 Cards - Won't Boot With 15 Cards
Hi All, hoping you can help where ASUS support fell short.
If I run my H370 Mining Master board with 14 cards, everything works as expected. Add a 15th card and I never see the ASUS bio splash screen nor does it bootup.
When I boot with 14 cards in these USB/PCIe slots, I have no issues: A01 - A07, B08 - B08 - B12, and C14, C17, C18
If I add a 15 card in any slot, it won't boot. I've also swapped out cards by adding a new card and plugging it in on A01 just to make sure it works. So then i try to boot up again with the new card in A01 and moving the original card from A01 and plugging it into C20 with no luck.
Adding a 15th card on either rig prevents a successful boot. All the cards, board fans, and PCIe risers power up just fine but never see the ASUS boot splash screen.
Thanks in advance for your help.
Cheers
Latest posts
