I was using default mode for the Corsair H80i which was still a little too loud for me so I switched it to quiet mode which is much better while gaming. The problem is, If I was running stress testing my temps would go much higher than it would with default mode set. So I clicked on i7-2600k Avg C Temp went to notifications on that, I left minimum at 0 unchecked but max I checked and made the box say 60. So when the Average temp of the i7-2600k reaches 60 there is an option to trigger all RGB lights, set fan speeds to 100% (which is what I'm trying to do), send an email, shutdown PC. This feature does not work at all. It's getting the correct temperature readings and everything but I checked the box (maximum) and made that 60 and I also checked set all fan speeds to 100 then I clicked on h80i fan 1 and h80i fan 2 and set the group to i7-2600k Averg temp and when it reaches 60C it does NOT go to 100% fan speed like it should. Am I doing something wrong? I mean I have the newest corsair link software version 2.4.5110.41697.
Why create a feature that does not work? I have to be doing something wrong...
Also, sometimes when my PC goes into standby and I wake it up, all the fans RPM say 0 for everything. It's a shame that such a good feature doesn't work 🙁
