H80i fan replacement
Jon Marple
13
I am looking to get new fans before I put in my new H80i cooling system. I put in one of the fans to test it before I put the new system in and the stock fans are insanely loud. I've been looking for new fans but this is all new to me and my head is spinning around in circles. Since I will be putting in two fans, I can lose some CFM per fan to compensate for the extra fan that will be put in. I have compiled a list of fans that I have been looking at but I can't get myself to pull the trigger on anything too quickly.
Current fan (as far as I know):
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181040
New fans:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608026
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103022
http://www.newegg.com/Product/Product.aspx?Item=N82E16835352007
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103091
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553007
I would appreciate some guidance in the world of fans, if there are fans that I haven't found that you would suggest me to try, please point them out.
I found the part two with tons more fans on it and I think I've settled on the Enermax Magmas, thanks for all your help!
