Hello everyone,
I will try to explain this as clear as possible and will go through all the details that I tried to solve this. This began rather anonymously from what I remember, and I seem to be having my HDD at 100% usage constantly or randomly, when opening any program or when playing games. I bought a new HDD 2 months ago (Seagate Barracuda SATA 3, 2 terabytes) and installed windows 10 on it.
It was working as intended for 2 weeks or so, and after a while, the 100% usage begins for no obvious reasons. The thing is even though Task Manager shows small programs that run on everyone's computers, mine is constantly at 100% when doing something or even when I'm idle just waiting for it to stop, it doesn't even show what program is using the disk that makes it at full load. At the time I was also getting random MEMORY_MANAGEMENT blue screens of death during gaming or simply browsing or doing my projects. The weirdest thing is since this HDD was bought 2 months ago, it makes an uncomfortable clicking noise each time it reaches or stays at 100%, it really sounds like the HDD is torturing itself for no specific reason.
I have tried numerous things and I will count them down. I tried doing the Windows Memory Diagnostic and it showed a great result with no errors, moving on. I tried Changing SATA cables and ports but nothing happened. I tried installing windows 7 but the 100% usage still persisted and the clicking noises were there as well. I turned off all the unnecessary Windows Services such as Superfetch, Windows search and many more, but to no avail. I tried formatting the whole new HDD to freshly install windows 10 and that worked for 2 weeks until it began to reach 100% load again as always. I ran Malwarebytes antivirus to check for threats, but everything seems in order. I used CrystalDiskInfo and CrystalDiskMark to check if the new HDD is failing for some reason, but everything is working as it should. On the other hand, the GPU drivers seemed to have problems as well. When Windows 10 was freshly installed, the Nvidia drivers refused to install, claiming that the installation has failed for some reason (?). I did some digging but nothing helped on how to fix it. Strangely enough, the drivers did install after a while of messing around on my PC. Even further into this whole mess, when playing a game or browsing my sounds become distorted and stuck on the same frequency which happened randomly, I believe the sounds get stuck once the HDD experiences the 100% load and it receives a temporary "shock". I know that the PSU is not a problem because I get BSOD, the PC doesn't get shut down due to lacking power. I was playing games yesterday and the 100% usage began again but it wasn't slow or anything really. Today I powered up my PC and I get BSOD, slow performance and my GPU drivers failed, they won't even install anymore because of that error that I mentioned earlier.
I really need help because this has gone too far, I've spent if not 50 hours altogether just trying to fix this but I can't find the problem. My BIOS is clean and optimized, even resetting it to factory settings didn't help. Removing RAM sticks also didn't help at all. Thank you for reading, I know that it's too long for you to read, but this is all that I can explain what I did, checked and tried fixing.
My specs:
Motherboard - AsRock Z77 Extreme4
CPU - i7-2700K (OCed to 4.0 GHz)
RAM - 2x4 DDR3, 1600 MHz
GPU - GTX 650 Asus Edition 1GB
PSU - 500W
Thank you for your time, I really hope that we can work this out!
My specs:
PSU - 500W
