Hard Disk problem
Dan
2,208
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hello, today when I started my computer (XP Pro Sp2 updated) it gave an
error about a corrupt file and said to run chkdsk. I ran it, found
problems so ran it again with /f. It apparently corrected the errors.
The computer restarted, I ran chkdsk inside Windows again and it found
another error. I ran in it again with /f after restart and corrected.
It restartaed, ran again and found no errors.
Now I ran it again inside XP and if found this errors:
C:\Documents and Settings\Daniel>chkdsk c:
The type of the file system is NTFS.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Deleting index entry tmp.edb in index $I30 of file 10204.
Deleting index entry schstorage.dat in index $I30 of file 12105.
Deleting index entry SCHSTO~1.DAT in index $I30 of file 12105.
Deleting index entry _L6622~1.KLT in index $I30 of file 12115.
Deleting index entry _L904B~1.KLT in index $I30 of file 12115.
Deleting index entry _LE3AF~1.KLT in index $I30 of file 12115.
Deleting index entry _LOCAL_0741fee6-fece-4a4d-b703-ca8d0c7d9d4d.klt in
index $I
30 of file 12115.
Deleting index entry _LOCAL_1cc36865-1840-414f-b955-6268904d6e52.klt in
index $I
30 of file 12115.
Deleting index entry _LOCAL_4ece1c30-e9fc-449a-9592-c8db14ce869a.klt in
index $I
30 of file 12115.
Deleting index entry _LOCAL_9feb997a-4f84-49ec-ad35-1061e92cea8a.klt in
index $I
30 of file 12115.
Deleting index entry _LOCAL_ad2c7bf3-b3e8-4bc7-84fe-a722e1c87af8.klt in
index $I
30 of file 12115.
Deleting index entry _LOCAL~1.KLT in index $I30 of file 12115.
Deleting index entry _LOCAL~3.KLT in index $I30 of file 12115.
Deleting index entry 1eb3cde6-4890-4a62-b22b-551058a6e0ea in index $I30
of file
12129.
Deleting index entry 1EB3CD~1 in index $I30 of file 12129.
Deleting index entry 5fd89dc7-b44c-437c-b136-4088a00f3f53 in index $I30
of file
12129.
Deleting index entry 5FD89D~1 in index $I30 of file 12129.
Deleting index entry 717955c3-23ef-4b0d-87e7-ddce76c59974 in index $I30
of file
12129.
Deleting index entry 717955~1 in index $I30 of file 12129.
Deleting index entry 853cc556-6dd0-41bc-9b3c-8d11b5cb1125 in index $I30
of file
12129.
Deleting index entry 853CC5~1 in index $I30 of file 12129.
Deleting index entry a8cc1ce9-ea5e-4859-b293-85288bbd659c in index $I30
of file
12129.
Deleting index entry A8CC1C~1 in index $I30 of file 12129.
Deleting index entry f87c2f3f-5d7a-4c61-8991-00b8ba88a32c in index $I30
of file
12129.
Deleting index entry F87C2F~1 in index $I30 of file 12129.
Deleting index entry SS_RUNTIME.xml in index $I30 of file 12134.
Deleting index entry SS_RUN~1.XML in index $I30 of file 12134.
Index verification completed.
Errors found. CHKDSK cannot continue in read-only mode.
The thing is that if I run it again with /f it corrects something, then
runs again, says the disk its fine and boots into XP. And inside XP it
gives more errors.
Any ideas about this error?
-Dan.
p.d. in the event viewer this appears:
Event Type: Error
Event Source: Ntfs
Event Category: Disk
Event ID: 55
Date: 4/13/2005
Time: 11:47:54 PM
User: N/A
Computer: DANIK
Description:
The file system structure on the disk is corrupt and unusable. Please
run the chkdsk utility on the volume C:.
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 00 00 00 00 02 00 4e 00 ......N.
0008: 02 00 00 00 37 00 04 c0 ....7..À
0010: 00 00 00 00 32 00 00 c0 ....2..À
0018: 68 00 00 00 00 00 00 00 h.......
0020: 00 00 00 00 00 00 00 00 ........
p.d.2 the disk is a seagate sata 120 gb new.
Its a Seagete Disk, SATA 120 GB
I just tried it again and running it inside XP gave me:
Correcting error in index $I30 for file 31237.
Deleting index entry A0028238.sys in index $I30 of file 31237.
Deleting index entry A0028239.exe in index $I30 of file 31237.
Deleting index entry A0028240.sys in index $I30 of file 31237.
Deleting index entry A0028241.sys in index $I30 of file 31237.
Deleting index entry A0028242.sys in index $I30 of file 31237.
Deleting index entry A0028243.sys in index $I30 of file 31237.
Deleting index entry A0028244.sys in index $I30 of file 31237.
Deleting index entry A0028245.sys in index $I30 of file 31237.
Deleting index entry A0028246.sys in index $I30 of file 31237.
Deleting index entry A0028247.dll in index $I30 of file 31237.
Deleting index entry A0028248.dll in index $I30 of file 31237.
Any more ideas?
dan
I ran the test, here is the result:
SeaTools Desktop v3.00.07
Copyright (c) 2004 Kroll Ontrack Inc.
4/14/2005 @ 7:47 AM
The following information has been generated by SeaTools Desktop. Use
this information to help you recognize and resolve potential data
access
problems.
System Information:
BIOS Date 09/05/03
Conventional Memory size 630 K
Extended Memory size 1046436 K
IO Channel type PCI
Drive Information:
SIZE MODEL
120 GB ST3120827AS
Serial Number = 5MT0HGDR
Int13 Num = 81, PHYS CHS = 16383x16x63.
ParmTable CHS, Rsvd = 14593x255x63
PARTITION CYLINDER SIZE
# Type Start End MB
PRIMARY
1 NTFS 0 3823 31455
EXTENDED
2 NTFS 3824 14591 88575
Diagnostic Results:
90-Second Test Result: Passed
Recommendation:
The "Quick Test" is adequate for most situations.
Consider running the "Full Test" which
verifies each sector on the drive if you need to run a more
comprehensive diagnostic.
SMART Status Check Result: Unsupported
S.M.A.R.T., (S)elf (M)onitoring (A)nalysis and (R)eporting
(T)echnology, a built-in hard disk drive failure prediction method
reports an 'Alert' if a problem has occurred. It reports 'Passed' if
no problems are found and 'Unsupported' if a hard disk drive does not
support S.M.A.R.T.
Full Diagnostic Scan Result: Passed
File Structure Test Result:
Partition 1 (NTFS (31.4 GB) ) Result: Failed with critical
Errors
NOTE: Any report of possible errors in the file system tests are
for
informational purposes only. We suggest you should consider
testing with
the official file system diagnostic utilities for your operating
system.
Seagate is not able to assist with troubleshooting or reviewing
file system test results.
Partition 2 (NTFS (88.5 GB) ) Result: Failed with critical
Errors
for
testing with
system.
Recommendation:
All selected physical diagnostics passed.
If you are not experiencing data loss and SeaTools reports File
System Structure errors, they may be caused by a lock-up or
failure to shutdown Windows correctly. Many times, these errors
may be repaired through normal system maintenance which
includes using the Windows provided "Defrag" and
"Scandisk / Chkdsk / Error Checking" utilities.
If you are experiencing a hardware error, you should isolate
the cause and replace the failing component. If you are unsure how
to proceed with repairs, contact a computer professional. After
completing any maintenance tasks, run SeaTools again to
verify that all errors have been repaired. If errors continue to
occur, the system may not be stable. Again, contact a computer
professional.
/Dan
Hi Brian.
I did all the tests available including the long one.
I will check first about the cables.
I will try again tonight(Im not home now) to do the chkdsk c: /r. I
will post back results as soon as i have them (probably in 12 hours).
Thanks again,
Dan
You do not say what brand of HHD you have, but most manufacturers have a
program that will analyze the HHD. I know for a fact Western Digital does
as I just had a HHD failure and to get the HDD replaced they required that I
run the analysis. It was easy to do and took only a few minutes.
With this info in hand, WD immediately replaced my HHD.
I suggest you try to find the analyzing program for your HHD. It is not a
bad idea to run this program occasionally anyway.
Hope this helps and good luck.
"Dan" <gamesstate@gmail.com> wrote in message
news:1113459889.722727.305400@o13g2000cwo.googlegroups.com...
index $I
30 of file 12115.
index $I
30 of file 12115.
index $I
30 of file 12115.
index $I
30 of file 12115.
index $I
30 of file 12115.
of file
12129.
of file
12129.
of file
12129.
of file
12129.
of file
12129.
of file
12129.
gives more errors.
-Dan.
Event Type: Error
Event Source: Ntfs
Event ID: 55
Date: 4/13/2005
Time: 11:47:54 PM
User: N/A
Computer: DANIK
Description:
Data:
news:1113482705.195782.105830@o13g2000cwo.googlegroups.com...
> Any more ideas?
> dan
Go to http://www.seagate.com/support/seatools/ and download the Seagate tool
(as per Jerry's suggestion) to diagnose whether your disk is on the way out.
I've not used their tools but if they are anything like the ones I have used
then it should be clear whether the disk drive is faulty. If the drive is
faulty then you need to get it replaced.
What you've indicated so far sounds to me like a duff drive. I suggest you
take a copy of all your key files so that you at least have a backup if it
does finally die on you.
Brian.
www.cryer.co.uk/brian
news:1113489455.051925.280870@z14g2000cwz.googlegroups.com...
> Is there a better tool than Chkdks to do disk error fixing?
> -Dan
Firstly, the output you posted doesn't seem to indicate a drive failure (but
anyone else out there who thinks I'm wrong please but in!!). Did I get the
impression that it did a quick test and that a longer one is available - if
so try running that.
Regarding chkdsk. I find chkdsk better than anything else available.
Try, after you've backed up key files (re my previous posting) and done the
longer disk check:
chkdsk c: /r
the /r flag (as opposed to the /f flag) fixes errors and then does a disk
check of every sector - it takes an age, but if there are areas of the disk
which are going bad (an indication itself of disk problems) then this will
find them.
Something else to try - possibly before the above - check that all the disk
cables are snugly in place. If a cable is a little loose then it might give
you intermittent problems.
Hope this helps. I know how horrible it can be with disks fail.
all the best,
Brian.
news:1113495136.098505.105710@g14g2000cwa.googlegroups.com...
> Hi Brian.
> Thanks again,
> Dan
Be aware that with the /r option chkdsk takes ages and ages and ages ... you
get the picture.
> Any more ideas?
> dan
Delete all partitions and repartition, format and reload. If the problem
persists junk the harddrive. If it persists on a new drive, junk the
motherboard, the hdd controller is broke. Now you have two good harddrives
and a new motherboard.
Um, do you mean HHD? or HDD?
johnf
> does as I just had a HHD failure and to get the HDD replaced they
> required that I run the analysis. It was easy to do and took only a
> few minutes. With this info in hand, WD immediately replaced my HHD.
> not a bad idea to run this program occasionally anyway.
> index $I
> 30 of file 12115.
> index $I
> 30 of file 12115.
> index $I
> 30 of file 12115.
> index $I
> 30 of file 12115.
> index $I
> 30 of file 12115.
> of file
> 12129.
> of file
> 12129.
> of file
> 12129.
> of file
> 12129.
> of file
> 12129.
> of file
> 12129.
> gives more errors.
> -Dan.
> Event Type: Error
> Event Source: Ntfs
> Event ID: 55
> Date: 4/13/2005
> Time: 11:47:54 PM
> User: N/A
> Computer: DANIK
> Description:
> Data:
