I still have warranty for this hard drive. How am I going to convince them to replace it? right now the HDD sounds quiet... I did dskchk S.M.A.R.T. and no bad sectors found. But I'm also looking at the possibility of my psu fan getting stuck because it sounded exactly like my other fans getting stuck months ago...maybe I'm looking at the wrong problem.
IT also has the same sound as this:
https://www.youtube.com/watch?v=sFe6Z8mVlwE I can't distinguish between the two in the first video, but I think this one is more accurate... the problem is all fans are spinning but I never checked the PSU fan since the sound seems to come from inside well duh... I removed the HDD sound problem was gone since I reconnected it maybe the PSU fan spun again.
UPDATE: The uploader of the first video I shared has responded and told me HDD's does not make those sounds... he found the problem... a freaking FAN going haywire >_<
also here is my report
CHKDSK is verifying files (stage 1 of 5)...
293120 file records processed. File verification completed.
338 large file records processed. 0 bad file records processed. 2 EA records processed. 63 reparse records processed. CHKDSK is verifying indexes (stage 2 of 5)...
346520 index entries processed. Index verification completed.
0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 5)...
293120 file SDs/SIDs processed. Cleaning up 783 unused index entries from index $SII of file 0x9.
Cleaning up 783 unused index entries from index $SDH of file 0x9.
Cleaning up 783 unused security descriptors.
CHKDSK is compacting the security descriptor stream
26701 data files processed. CHKDSK is verifying Usn Journal...
35806656 USN bytes processed. Usn Journal verification completed.
CHKDSK is verifying file data (stage 4 of 5)...
293104 files processed. File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
95919730 free clusters processed. Free space verification is complete.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
493459455 KB total disk space.
109257892 KB in 229192 files.
112376 KB in 26704 indexes.
0 KB in bad sectors.
410267 KB in use by the system.
65536 KB occupied by the log file.
383678920 KB available on disk.
4096 bytes in each allocation unit.
123364863 total allocation units on disk.
95919730 allocation units available on disk.
Internal Info:
00 79 04 00 a1 e7 03 00 ef 6d 06 00 00 00 00 00 .y.......m......
c0 0a 00 00 3f 00 00 00 00 00 00 00 00 00 00 00 ....?...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Windows has finished checking your disk.
Please wait while your computer restarts.
