So, I have this problem with my internall HDD. I will try to give as much details as I can.
I have a HDD of approximately 300 GB. I have Bios, not UEFI, and the in the disk management it shows the disk as MBR.
When I first bought my laptop it had windows 7 pre-installed. However, i decided to install windows 8.1 after a year and some months. Then, and this is where it all begins, I decided to try to dual-boot Windows 8.1 and Ubuntu. It did not go as planned and I messed up windows, and could only access ubuntu after that. I then somehow fixed my HDD with the bootable Windows 8.1 pen drive and installed Windows 8.1 all over again. A couple months later, when Windows 10 came out, I upgraded (not clean install) to Windows 10. I than thought about trying to dual-boot ubuntu again as i thought I had found the problem I had earlier with dual-boot. I shrank my HDD in 40GB, so that I could use that space to install Ubuntu. However, I left it there and now, a few months after, i tried to make a partition out of those 40GB through disk management. However, an error occurs when i try to do it, something like "the selected GPT formatted disk contains a partition which is not of type 'PARTITION_BASIC_DATA_GUID' and is both preceded and followed by a partition type 'PARTITION_BASIC_DATA_GUID' ". Using another disk management software (EaseUs) it shows the unnallocated space is of logical type.I really don't know what i may have done. I will attach some prints. The language is Portuguese but i believe it will be easy to understand. Can you please help me? Thank you for your time.
