Hard drive disconnecting and reconnecting
gxavier38
249
Hi
I'm having a bit of a problem here
My external hard drive (a Hitachi 500GB 2.5" drive) which is connected to a Silverstone RVS02 keeps disconnecting
When I plug my hard drive in (With both USB cables), Windows detects it, but after 5 seconds or so it starts disconnecting and reconnecting every second or so
Once a while I get prompts to format the drive
The disconnects do not stop until I unplug the drive, or at least the data one
I've checked my power options and tried almost everything
This is the only USB device that this happens to, and it only happens on this PC so I don't think it's the enclosure
I've tried other USB ports and this also happens
Any help would be amazing
Thanks
I recently discovered this problem too.
What is happening is that usb3.0 has some power saving mode that lets the hard drive power down.
Here is the fix.
control panel/power options/change plan settings/change advanced power settings/USB settings /USB selective suspend setting
The set the plugged in option to disabled.
Oh and for more info
This only happens when the data cable is connected to a USB 3.0 port
When it's connected to a USB 2.0 port this doesn't happen
The other computers I tried this on only have 2.0 ports
I've tried updating USB 3 drivers on my motherboard (AsRock Z77 Extreme4)
This is the only USB 3 cable I have though
Could it be the problem?
Here is the fix.
Reactions: Shinobi0072
In addition to the solution posted above, you should install the latest USB 3.0 drivers.
Also go into Device Manage and locate the USB Root Hubs, go to their properties, then the power management tab, and uncheck the settings in there.
I created an account only to thank you.
Hi people,
I had the same problem, tried the suggested solutions without success. I updated Intel(R)_USB_3.0_eXtensible_Host_Controller_Driver with one compatible with intel's 4-th generation cpu's and it works :)
good luck!
I'm on intel's site but I'm having trouble finding the driver. I'm at this address.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+8+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DZ87KLT-75K&ProdId=3598&LineId=3597&FamilyId=36
This worked for me. For me it was a WD drive and it was really annoting because i had all of my steam games on it and when I was in a game it would close down. Thanks!!
Thank you. I was certain my hdd was failing but your solution worked. It's weird that Windows put the ports to sleep even during copying. And I also have an external power supply connected to the hdd so Windows must shut the port down completely not only the power to it.
Also made an account just to say thank you. You saved me a lot of trial and error.
USB was originally conceptualised to only be used with short cables (i think 120 cm was the limit). If i am not mistaken, the reason was data throughput couldn't be guaranteed one there was more cable to get through. Over time, manufacturers began ignoring this limitation resulting in issues like the one described here.
The power saving feature recommended as the first solution did the trick for me, so a thank you from my side. After years of using Tom's as a silent viewer only, i finally created an account to say just this: thank you! :)
shorter USB cable worked for me. Thank you jackjackffm
Right on!
Thanks jackjackffm, I first tried the power saving solution and no luck.
You are correct the length of cable fixed the issue.
I was using the front I/O USB port on my computer which has a cable from the motherboard to the I/O port and then the cable to the hard drive...total length=toooo long.
Plugged the same external hard drive cable directly into the USB port on the back of the computer which is direct USB on the motherboard and the now the drive does not disconnect on me.
Here is the fix.
The set the plugged in option to disabled.[/quotemsg]
But it doesn't work for me. WD My Passport is my device. I update firmware, SES driver, USB root hub power management box check out, disabled power oftion from usb settings. nothimg worked for me.... I have 2 hd same model and same problem connecting/disconnecting automaticly
Hi All,
Same problem here with a Transcend HD 2.5, 500GB.
Things I tried out without any success:
- Bought a new cable (double USB plug) - no luck
- Changed all the Power Settings in Windows 8.1 for all USB ports - no luck.
- Tried to plug into USB 2.0 ports - no luck
It keeps connecting and disconnecting.
Any other possible idea that would help solve this problem ?
Cheers,
Sascha
had the same problem... and this guy is the one to fix it.. wtf 😀
i mean.. WTF.. i was sure he was trolling, i even laughed at him, until i tried it xD
thanks dude(s) made an account just to write this
I believe faulty cables are a big problem with USB 3.0. I have many USB 3.0 cables and devices and only a select few will work without continuously disconnecting. Hard to say which brands work best, but when I have a problem, using a known cable that works fixes it.
Found the answer. Needed a powered usb hub. Fixed the problem. The device was not getting enough power. I'm using a toshiba 2tb external hd and a asus transformer t100ta.
Picked up a belkin desktop hub.
Seems to fail when I have multiple hd's connected tho.
Hope this helps.
