M.2 ports are also used up. What other options do I have?PRIME B560-PLUS - Tech Specs|Motherboards|ASUS Global
PRIME B560-PLUS Intel® B560 (LGA 1200) ATX motherboard features PCIe 4.0 support with SafeSlot core+, two M.2 slots with one flexible M.2 heatsink, USB 3.2 Gen 2, Thunderbolt⢠4 support and Intel® 1 Gb Ethernet. Prime B560-PLUS caters to daily users and all builders looking for well-rounded...www.asus.com
The board has two M.2 ports.
Use them...or replace one of the SATA drives with a larger SATA drive.
I just want to add more SATA hard drives, not replace current ones with larger sizes. Most of my current ones are WD black and I got it cheap. Now prices are through the roof.
All are crappy options or too expensive.
Put 'sata expansion card' into google see if that works for you.I am looking to add additional Hard Drives for my home PC.
My mobo SATA ports are all used up. Mobo is ASUS prime b560 plus.
What are my options?
If you still have free PCIe slots then you could install an internal SATA port card to add more internal ports. Storage performance is great compared to USB, but unlike USB or motherboard headers the attached drives will not be bootable.
Or a PCIe M.2 card adapter is in many cases bootable.
s in india prices alw
Why not just increase the size of a couple you have now?I am looking to add additional Hard Drives for my home PC.
