Hard Drive is stuck IN Tray
4
Please help my hard drive isn't stuck in my tray and will not comeback out at all! My pc case is the aercool cyclone rgb. How do I take it out.
You have the Aerocool Cylon? Not Cyclone?
Has the drive trays under the basement at the front, yes?
Should just be a matter of unscrewing it if screwed in. That might require further disassembly of the case. If they are toolless trays then you probably just need to apply a little pressure to the sheet metal outwards to make a little more room.
If it uses rails, it should be a matter of pushing the rail clips together, which would then allow you to pull the drive out. You'll have to find those clips on the rail, which might be facing the other way if you installed it like that.
I did the same thing ):
