My WD Green HDD isn't showing up anywhere! Not in BIOS, not in disk management, not anywhere!
The drive stopped working after temporarily unplugging it.
I've tried everything...
- Made sure power and data connectors are in properly from all the sides
- Tried using different cables
- Tried plugging in different combinations of all the drives I have
- Tried different BIOS settings (although I'm not too sure about that, I think the drive should be read regardless the BIOS settings)
- Tried resetting BIOS settings
I know that drives sometimes need to be enabled through disk management, but it's just not there!
The drive itself is spinning, so I'd assume that it gets enough power. It seems like there might be something wrong with the SATA connector on the HDD (or maybe something inside it)?
What are my options? What can I do? Is there a way to repair it somehow? I can't even use data recovery tools because it's not being read by anything at all!
Please help!
Please help!
