hard drive not working on TV
John_676
Hi, I have a two 1tb hard drives, both with movies and tv shows on them. they both work fine one one of my TV's through my ps4 but when I plug one into my usb point on my small bed room TV it shows that its connected but nothing shows up on it. Anyone any ideas??
Many TVs specifically state in the manual that they do not support Hard Drive power requirements for the USB ports, only flash physical medium. Also, does your TV support the filesystem? Not indicated if you are using FAT or ExFAT. Your TV will need to support ExFat if that's how you formatted it. Have to agree with The Paladin. The answer is most likely in your TV manual, and if not, then post the name and model number as well as the hard drive name and model number as there may be an errata with the combination.
