Hard drive problem
WDaditya
4
My one tb WD pasport recognizing in windows but not opening while in MAC it is opening and in MAC the data is read only so pls suggest any solution
WDaditya
4
no the problem occurred when i unplugged it from desktop now it is recognizing in windows but not opening and not showing any properties i thought data is lost but just as try i attached it to mac it opened and data is ok but in mac it is read only so suggest me any solution
MacBoy256
All depends on where you initially initialized and formatted the disk. If in Mac, use Mac Disk utility to correct the errors, if in Windows, right-click the disk in Windows Explorer, select properties, then Tools, and click Check now...
But before,
BACK UP ALL THE FILES ON THE DISK!!!!!
WDaditya
4
Thanks
but the external hard drive is recognizing only in windows can't check properties and neither it is opening nor it showing used and free space. The same hard drive in mac working ok but the file system is NTFS so in mac it is read only thus I don't have any way to back up data. so pls give some thoughts I need the data
thanks
