Hard drive problem?
vampyiere6
832
Hello!
So i have a co-workers laptop that i need to repair, so i started it up and it was extremly slow, it runs on windows 7.
and as there was nothing on it that needed to be saved i did reinstall windows on it and that too was really slow, and it had many problems to login windows while installing, where it is prepering the desktop it restarted about 5 times and it had many errors while prepering internet explor etc.
So i just left it since it was late and started it up next day and now it did boot into windows but it is really slow.
but i cant open anything like ie to downloaded programs etc i get a error, so i moved the programs i needed to check the harddrive etc but i cant install anything either only errors.
i dont remember the errors exact since i took out the harddrive and puted it in sata to usb and connected it to my own computer.
and i did run crystalDiskInfo on it and the harddrives health status is caution because of rellocated sectors and current pending sectors.
And the hdd has 4 driver letters assignet its puted up in 4 partions G,H,I,J and one of them is the system restore/backup point so its 100mb the other is 200mb and one 25gb.
its been used 2623 hours and 2000 power on counts.
So i would like to delete the partions and totaly format the harddrive so its just assigned 1 driver letter and then check if it has many bad sectors still.
The laptop it self has 4gb of ram a dual core amd cpu wich is pretty weak, and it has overheated too as it did once too me over 90 degrees celcius and shutdown and idk how many times before it have had that problems but i cleaned the fans and sink and now its in ok, so idk if the cpu or so is damaged.
but if it is the harddrive i will see if i think its worth to get a new harddrive for it or if the laptop is in too bad shape afterall.
to know for sure that it is not a heating problem you need another HDD to put on the laptop.....since the old one already is beginning to fail. that way you can isolate the problem.
i have cleaned the fan etc already it is fine now.
So should i just get a new drive? so its not worth formating the drive etc at all?
All these errors etc is harddrive related? thats what it should be in my opinion. or could the cpu or so been damaged by the overheating? since as i said this is not my laptop i cant know how many times it has done it before.
Hey vampyiere6. As qazzi said, this is probably because of the drive. Even if you format it and manage to relocate most of the bad sectors, it still won't turn out OK. Once bad sectors start to occur this will continue until the HDD fails completely and unfortunately I think this one is on the same track. The best course of action would be to get a new drive and try to backup any important data that this one might have.
Hope that helps.
Boogieman_WD
yea i think so too but its up to my co-worker if she wants to spend money for a new hard drive for it, then i can see.
Latest posts
