Hard Drive Starts and Stops Spinning every 3-4 Seconds
richrose
after installing windows 7, my desk top dell precision 380 hard drive starts and
stops spinning every 2-3 seconds.
Go to control panel, to power options.
select power plan that you're using, then click "change plan settings"
then go to "CHange Advanced power settings"
go to "USB settings", then "USB selective suspend setting"
then select disabled on "plugged in" (and if you're on a laptop, also do it for "on battery")
Do these steps on other power plans if you change them often
