Hard Drive Temperature Levels
Ritchie1988
Commendable
Jun 16, 2016
20
Hello everyone, simple question for you :)
Upon upgrading my GPU to a GTX 960 from a 730gt, I've been carefully monitoring my temps for my system using Open Hardware Monitor to be sure everything is ok! Sure enough everything is fine, and both my GPU and CPU are within good levels.
However, I noticed my Seagate 3TB HDD (model: ST300DM001) is getting up to 50 degrees give or take a degree or two when playing graphically intense games (for example Crysis 2) and idles around 40 degrees when just doing general stuff on the computer i.e browsing, email etc.
Having googled this, Seagate themselves say anything up to 60 degrees is completely normal with operating levels averaging between 5-50 degrees, at which I'm at the higher end of.
If anyone can give me their thoughts on this that would be great! :)
Thanks in advance!
my wd blacks red 32c but like said above my case has a hd bay fan seems like for WD they spec the temps up to 100c ??
look in your drives data sheet may show this info
or like here to see whats said
https://www.backblaze.com/blog/hard-drive-temperature-does-it-matter/
