warder348 :
OK, guess I'm old and dumb, if there's no OS on the drive how do you click on start, computer and manage to get to disk management to partition the drive? Sorry if this is a dumb question but as usual I'm lost again. I know your probably getting tired of answering my questions by now, but like a child I need a lot of steering in the right direction. Thanks again, will try hard not to bother you again!
Sorry about that, should have mentioned something about it earlier!
You can see from the second link I provided that you'll need to boot Windows from your installation media (bootable USB/DVD) first in order to achieve this.
When installing Windows, you need to select NEW partition where the OS will be installed, you choose the size of it, but you won't be able to change it later, it's only your System Reserved partition. (e.g. Windows 7 requires 16 GB of space). I like setting it to 100 MB just in case.
Once the Windows installation is finished, you will be able to get to Disk management to initialize (a.k.a. partition and format) the rest of the HDD and put it to use.
Actually there are a lot of tutorials you can google, but here's a good one with detailed pictures:
http://www.windows7ultimate.windowsreinstall.com/windows7installguides/indexfullpage.htm
Good luck!
SuperSoph_WD
