Hardrive problems or gpu problems????
goga12
270
Ok so i having this problem that sometimes when i switch my pc on it does not show any graphics on the screen just black and case everything spins up and so on.Then i must restart the pc maybe three times before i get my login screen and it too work.what can be the problem?
It`s normally a sign of a aged power supply unit in most cases Goga.
If you have had the Psu for some years, and it`s had a lot of use.
The older a power supply is and the longer it has been running it degrades in the amount of peak power it can deliver over a few years of use.
It can also be a sign if the power supply is only a few months old, that is is a very cheap unit. or that the wattage it actually outputs in peak wattage is not what is stated on the power supply unit label.
In most cases that applies to cheap power supply's with a little known brand name that would cost you £30 to £40 to buy.
In both cases it points to the power supply unit in the system, at fault.
The only real test without spending any money, and to confirm it is the power supply is borrow one off a good friend you know has no problems and test the system with it for a few hours.
If it works with the power supply, then you know it`s time to buy a new one for your system Goga.
well this is a new psu everthing is new have had this system for a few months now almost a year.no overclocking or anything and it not a cheap one an antec gold certified psu and if it was the psu the system fans would not spin up or the cpu fans. any other ideas?this all my system parts.can it be dust?
AMD FX-8320 Vishera Black Edition 8-Core 3.5GHz (4.0GHz Turbo) Socket AM3+ Desktop
ASUS M5A97 LE R2.0 AMD 970/SB950 Socket AM3+ ATX Desktop Motherboard
G.Skill F3-1600C9D-8GAB 8GB (2x4GB) DDR3-1600MHz 1.5V CL9 Dual Channel Ares Desktop Memory
PowerColor AXR9 270X 2GBD5-TDHE/OC TurboDuo Radeon R9 270X 2GB GDDR5 PCI Express 3.0 256bit Graphics
Antec TP-550C TruePower Classic 550W 80PLUS Gold Certified Desktop Power Supply
Seagate Barracuda ST1000DM003 1TB SATA III 7200RPM 64MB Cache 3.5" Internal Hard Drive - OEM
LG GH24NSBO Internal SATA 24x Super-Multi DVD Rewriter
