I'm building an HTPC and keep having problems with it rebooting or blue screen after about 10-15 min. of use. Below is a report from Everest just before a crash. Are the negative voltages to high? I can only get the CPU fsb up to 150mhz instead of the normal 166mhz. Any help would be appreciated, it's frustrating, can't use my Beyond TV or any media applications longer than 10-15 minutes. I can post a more detailed hardware report if anyone feels they have an idea what to look for...
Thanx in advance!
Field Value
Sensor Properties
Sensor Type Winbond W83697HF (ISA 290h)
GPU Sensor Type Driver (NV-DRV)
Motherboard Name MSI MS-6712
Temperatures
Motherboard 32 °C (90 °F)
CPU 44 °C (111 °F)
GPU 55 °C (131 °F)
Seagate ST3250823A 35 °C (95 °F)
Seagate ST3200822A 35 °C (95 °F)
Cooling Fans
CPU 3750 RPM
Chassis 4219 RPM
Voltage Values
CPU Core 1.66 V
+3.3 V 3.23 V
+5 V 4.95 V
+12 V 11.98 V
-12 V -12.77 V
-5 V -5.30 V
+5 V Standby 4.97 V
VBAT Battery 3.42 V
Debug Info F 2D 28 FF
Debug Info T 32 44 255
Debug Info V 68 00 CA B8 C5 1A 30 (01)
--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/
Report Type Report Wizard
Computer
Generator
Operating System Microsoft Windows XP Home Edition 5.1.2600 (WinXP Retail)
Date 2007-06-13
Time 00:31
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
OS Service Pack Service Pack 2
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name STUDYPC (StudyPC)
User Name Lyons'
Motherboard:
CPU Type AMD Athlon XP, 1954 MHz (13 x 150) 2600+
Motherboard Name MSI KT4AV (MS-6712) (6 PCI, 1 AGP, 3 DIMM, Audio)
Motherboard Chipset VIA VT8377A Apollo KT400A
System Memory 1024 MB (PC2700 DDR SDRAM)
BIOS Type AMI (12/01/04)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port ECP Printer Port (LPT1)
Display:
Video Adapter NVIDIA GeForce 7600 GS (256 MB)
Multimedia:
Audio Adapter VIA AC'97 Enhanced Audio Controller
Storage:
IDE Controller VIA Bus Master IDE Controller
Disk Drive ST3200822A (200 GB, 7200 RPM, Ultra-ATA/100)
Disk Drive ST3250823A (250 GB, 7200 RPM, Ultra-ATA/100)
Optical Drive IOMEGA ZIPCD3840INT-A (12x/10x/32x CD-RW)
Optical Drive SONY DVD RW DRU-510A (DVD+RW:4x/4x, DVD-RW:4x/2x, DVD-ROM:8x, CD:24x/16x/32x DVD+RW/DVD-RW)
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 238472 MB (222259 MB free)
D: (NTFS) 95872 MB (44651 MB free)
E: (NTFS) 94899 MB (72139 MB free)
Total Size 419.2 GB (331.1 GB free)
Input:
Keyboard HID Keyboard Device
Mouse HID-compliant mouse
Network:
Network Adapter VIA Rhine II Fast Ethernet Adapter (192.168.0.161)
Peripherals:
Printer \\VIAO\hp deskjet 5800 series
Printer Adobe PDF
Printer Auto Adobe PDF on VIAO
Printer Auto hp deskjet 5800 series on VIAO
Printer Microsoft Office Document Image Writer
USB1 Controller VIA VT83C572 PCI-USB Controller
USB2 Controller VIA USB 2.0 Enhanced Host Controller
USB Device USB Composite Device
USB Device USB Human Interface Device
Thanx in advance!
Field Value
Sensor Properties
Temperatures
CPU 44 °C (111 °F)
GPU 55 °C (131 °F)
Cooling Fans
CPU 3750 RPM
Chassis 4219 RPM
Voltage Values
CPU Core 1.66 V
+3.3 V 3.23 V
+5 V 4.95 V
+12 V 11.98 V
-12 V -12.77 V
-5 V -5.30 V
+5 V Standby 4.97 V
VBAT Battery 3.42 V
Computer
Generator
Date 2007-06-13
Time 00:31
Computer:
User Name Lyons'
Motherboard:
Display:
Multimedia:
Storage:
Partitions:
Input:
Network:
Peripherals:
Printer Adobe PDF
