[SOLVED] hardware issue mobo?
zachlittle7
6
changed to new case lian li air. switched everything over, it will run for 5 seconds and turn itself off. if i take the psu cable out for a while then put it back in it will boot up and i can get into windows and everythings fine.
i assumed it was the psu or mobo. ive tried a different psu the exact same thing happens. do you guys think it could be the motherboard? could have damaged something when changing over.
pc specs
Processor AMD Ryzen 7 1700X Eight-Core Processor, 3400 Mhz
gpu - rtx 2070
16gm ram
mobo - asus strix something i forget (come in a bundle with ram and cpu)
psu - corsair hx 850 wat (had it for 6 years)
yea ive tried all that ram slot change cmos reset etc. must be mobo :,(
what mobo would you recommend for the hardware i have? budget is around $150 usd
