News Hardware leaker claims RTX 5060 and 5060 Ti GPUs will use 8-pin power connectors
its possible.
FE might just be Nvidia doing nvidia stuff (forcing it on you regardless)
AIB's likely will take cheaper option to make most profit & 8pin is likely cheaper to produce & a 60 tier (even if 100w more) will not surpass the 8pin's rated delivery.
More important from the power connector, I hope that nvidia will use fast gddr7 vram and not the slowest, that will compensate for the small 128bit bus and will be an acceptable budget purchase.
