hrmmmmm,
A week ago I built my first system. I got some info from a few of the guys here on the boards that helped me out. Everything seems to be running NEAR perfect, and I am a happy camper. Problem is I get an hardware monitor error on post every once in a while. Here is the "post screen" text:
________________________________________
Award Medallion BIOS v.6.0, An Energy Star Ally
Copyright (C) 1984-2001, Award Software, Inc.
Asus P4S533 ACPI BIOS Revision 1008
AWard Plug and Play BIOS Extension v1.0A
Initializing Plug and Play Cards...
PNP Init COmpleted
Trend ChipAwayVirus(R) On Guard
Detecting Primary Master ...Maxtor 6L060J3
Detecting Primary Slave ...None
Detecting Secondary Master ...Toshiba DVD-ROM SD-M1612
Detecting Secondary Slave ...None
Hardware Monitor Found an Error. Enter Power Setup menu for details.
Press F1 to continue, Del to enter Setup
So I do the obvious and I enter bios and go to power. I look under hardware monitor and the only thing that indicates to me as a "flag" is the Chassis fan RPMs, and Power Fan RPMs, which are both in Red text. Now I have never really dealt with the bios much before, so captain obvious says to me that Red means BAD!
So I boot up into windows(XP) and I go into Asus Probe 2, and sure enough there too it is giving the lovely little "Dong dong" sound, and flashing before me is the same fans. They are performing below the "required" rpms that they seem to need to be performing at. Both are usually in the low 1600s.
Now my temperatures seem to be fine (CPU 40C/104F, MB 28C/82F) but I really don't know what "fine" is when it comes to all of this.
I've updated my bios to try and counter this problem, but it seems to still turn it's ugly head every once in while on post.
It actually used to read that the CPU fan speed was below it's recommended RPMs too, but it stopped that after a day or two. It now runs at 2700+ rpms.
Important system specs are as follows.
Asus P4S533
P4 2.26
Samsung PC3000
Antec 1080+ w/ 430watt true power
All antec fans besides the one on the CPU which is an Approved fan by Intel. Might Be Sanyo (not sure).
OH!, I gutted the system from a pitiful case and Powersupply. I forgot that part. I ordered a stock system from a company that was using non-oem parts and it was a good deal. Problem was, it was a sucky case with no air flow, so I gutted it and put it in what I just posted above. The problem DID occur in that Computer case as well. That was my first thought. It was the powersupply in this new case. But it did the same thing in the other one as well.
So any suggestions as to why this is happening? Any fixes that anyone could suggest?
Also, tell me if I am reading this all right and if there are any other "Red flags" I should look out for. I truly am just new to this side of computing. Hey, I'm a web designer! Art is my thang!
Thanks.
<b>If it aint broke, then hell, you aint looking at it in the right frame of mind!</b>
PNP Init COmpleted
Asus P4S533
P4 2.26
Samsung PC3000
Thanks.
