Nice cooler from what I have been hearing
One of the best air's, if not THE best for in-case situations. It functions as a perfect board cooler, which is needed since I have my board volts generally higher. I ran a tuniq, which had temps just as good, but my board got too hot. Tuniq is best for benching in open air, SI-128 with a "tall" fan that can pull in cool air from outside the case is best for in-case. I'm sure TTBT does the trick as well, but SI-128 is good until I jump to phase.
I guess I just dont see how anyone could be having temp problems with their board unless they are missing your typical
intake and exhaust case air flow setup.
I can only see it being a problem if you dont have at least 2 case fans, one for pulling air in and the other to exhaust it. Keeps everything nice and cool. It just seems dumb to not have decent case airflow.
With my setup my motherboard temps are only 32c and thats with my E6400@3.5ghz
My concern with mobo temps is for orthos runs. Run orthos blend for 24 hours and your board temps won't be 32c unless you have very low ambient. I do have good case airflow, but I also have a case full of raptors, an 8800GTX, and other heat sources. Without directed airflow near the sink, the NB gets blazing hot.
Running orthos blend overnight only gets my MB to 37c. For what its worth my room temp is 68F.
I have the following-
E6400@3.5ghz 1.4v core
Asus P5b delux
4gig DDR2@1000mhz 4 4 4 5 2.3v core
8800GTX@630c and 2030mem.
Soundblaster Audigy 4
37c is too hot for my board, because it's much hotter than what it reads. Also, you are running 965, I am running 975. NB is almost too hot to touch w/o fan blowing on it. I'm not sure if you're saying I'm imagining it's too hot to touch or what your ultimate point is. There is more than just the CPU to keep cool, and unless I have a huricane of airflow through the case, having air blow down on the NB when heavily overvolted is a nice to have.
