Haswell Build - Need some advice
Meng2strong
60
Hi All,
I am planning to build a new rig (first time) and have picked a list of components as a "first draft" of the build. I will be using this for both gaming and video editing. Any suggestion is always welcome, although I am pretty much maxed out on budget.
Build so far:
Gigabyte G1.Sniper 5 Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor
EVGA GeForce GTX 780 3072MB GDDR5 PCI-Express
Corsair Dominator GT 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad
Corsair Professional Series HX+ 850W '80+ Gold' Modular Power Supply
Intel 330 Series 120GB 2.5" SATA 6Gb/s Solid State Hard Drive
Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM
Swiftech H220 Compact Drive II PWM Water Cooling Kit
LG GH24NS95 24x DVD±RW SATA ReWriter (Black) - OEM
Corsair 600T Graphite White Midi Tower Window Gaming Case
The above components goes to around £2k-2.1k.
What I want to establish mainly is that are these components of decent "standards" against its competitors and how well I will be able to overclock the 4770k with the Swiftech H220 kit? (looking for 4.4ghz - 4.5ghz), it seems 4.4ghz is a popular number for 4770k overclocking.
Many thanks,
Meng
Build is really solid.
I've heard good things about the Swiftech H220. If 4.4GHz is popular to hit then swiftech should get higher.
The question I have is...will the Swiftech H220 work on 1150 sockets? I know it works on 1155 and AMD ones, but I'm not sure
if there is a modification for 1150 sockets.
It will be for gaming, video capturing and video editing.
I would think so, from what I have read so far I think it does and if not Swiftech will probably send new brackets out.
Ah. That being the case, fewer options for cuts. That said, you can take the RAM down to 1600mhz G.Skill Ripjaws X or Corsair Vengeance, which will save a bit, as would knocking the PSU down to a 600-650w (I would suggest XFX, as they tend to be extremely cheap relative to other SeaSonic-made PSUs). I'm also fairly sure that you can economize a bit on the motherboard, but I'm afraid that I don't know the Z87 mobos yet, so I can't suggest a specific alternative. On a non-savings note, I would suggest using Samsung instead of Intel SSDs, ideally from the 840 Pro series.
RAM I don't really mind although you have a point, I could cut down to 1866 or even 1600mhz. I was thinking of getting the 850w because I will probably eventually be running 780s SLI but I guess I could get a 600/650w for now and upgrade accordingly later. That is the most expensive motherboard, I haven't seen many comparisons on the net so I will have to wait for a few days I guess. Why is the Samsung 840 Pro series better than the Intel SSDs?
Thanks,
Meng
The main reason to cut RAM speeds is that speeds higher than 1600mhz don't really have any function (I only got 2133 because it was literally two dollars more, myself). Thus, any money you shave off there is free savings.
If an SLI is in your future, go for a bigger PSU. Once again, I recommend XFX for quality and low prices, or SeaSonic for pure quality.
I'm not quite understanding what you mean about the motherboard. Do you mean that the Sniper is most expensive? You'd definitely want to cut it down, in that case.
They're generally viewed as being higher quality, faster, and overall better. In fact, off the top of my head, I can't think of an instance where the Intel SSDs have been recommended or judged to be superior.
Thanks for replying, I think I will be downgrading the MoBo to the MSI Z87 GD65 Gaming MoBo as it seems to perform well for gaming and higher clock speeds when overclocked. I think I will just hold back on the PSU and get a smaller one for now and upgrade accordingly once I decide to go SLI. Ram I will be keeping, just me being anal attentive. Will be switching to the Samsung Pro series SSD as well.
Thanks for your help!
Meng
If you are seriously considering SLI then get enough wattage now. No need to upgrade PSUs. PSU are a very long lasting and stable component, assuming you choose a top quality manufacturer.
Since you are doing editing I'd go 1866. And like someone mentioned, if it's only $2 more higher RAM then get that.
I have the Intel 330 120GB and it is fantastic, but I got it last fall for $100. However, since your budget is bigger I'd recommend a bigger and faster SSD for under $200. Intel 520.
http://pcpartpicker.com/part/intel-internal-hard-drive-ssdsc2cw180a3k5
+1 on the PSU.
The guy who was paying $2 more was me, actually. I got a heck of a deal on my RAM. Don't think that OP has that option, though if he does he should definitely go for it.
Fair enough. I admit, I'm not well versed in Intel products, so if you're attesting on experience that it's solid, that's good enough for me.
Nice deal on the RAM. As for Intel SSDs...The 520 has a 5 year warranty. And Intel is known for making stable SSDs. I know my 330 isn't the fastest SSD but I doubt I'd notice difference between a faster one for my usage.
Yeah. My jaw rather dropped when they owner of the tech store I was at told me the cost.
If it's worked for you, that's good enough for me. I'm obviously not dead set on Samsung SSDs, being as I use a Mushkin myself (and would recommend them to others, if efficient prices can be found. I love this thing).
