Having a really strange problem need help
Stefanoodle
22
Hello im having some really bad frame rate issues that are intermittent when playing any game other than league of legends (dayz, smite, transistor, civ5, you name it). The frame rate just drops randomly and then returns to normal after a while although sometimes it wont go back to normal and i have to exit the game and restart, please help.
Thank you
Stefan
Specs
http://uk.pcpartpicker.com/user/multiplatformPansan/sav...
El Tigre
771
Your specs gave me a 404 error? By chance, do you have a EVGA GTX 680 FTW+ 4GB? If so, some of those cards have a small defect where the first 20 minutes or so of booting up your PC, any game you play will stutter and tye FPS will be erratic. After those 20 minutes or so, the regular performance returns.
EthanG
65
If you haven't already, start by reinstalling the latest video drivers. Use Display Driver Uninstaller (http://www.wagnardmobile.com/DDU/) to remove the old drivers completely.
Stefanoodle
22
Hi thanks for the fast response i dont have that gfx its the ASUS one.
Stefanoodle
22
Hi thanks for the fast response i have tried this a couple of times but no success i am really cinfused at to what is causing the problem.
EthanG
65
Have you checked card temperatures? Opened up the task manager to see if something else is using resources? Virus scan? Try reseating the graphics card.
Is it a recent problem? If so, do a restore point. If you don't have one, then do a fresh install of windows.
Edit: BTW, you're pc part picker doesn't show up.
Stefanoodle
22
Ok ive had a look using gpu tweak while playing saints row on ultra and it spikes all the time from 44% gpu usage + 38degrees to 99% gpu usage + 90degrees, im really concerend
Stefanoodle
22
Hi ive had no success i can show you some screenshots if that will help and sorry for the link not working ill provide you with that too. Thanks for your time :)
http://uk.pcpartpicker.com/user/multiplatformPansan/saved/PYyWGX
http://gyazo.com/db42ad1283aa521ad77a6bd5d6b5749c
http://gyazo.com/fc11e24753ae38f12dffd8de773e1447
http://gyazo.com/64c0d4f07936c32d4c5bccebadd8139d
http://gyazo.com/dc227df7d6717f016508f4c142a87e68
http://gyazo.com/fd1cd865fea62bee5131bfcf3a971012
http://gyazo.com/151b0060184ee78a5874f44052b50cb4
Also it makes no difference if i put the settings on low or high im seriously confused.
